주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 10.1 Battery Replacement
필요한 것
  1. Samsung Galaxy Tab 3 10.1 Battery Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Battery Replacement, Rear Case: 1 단계, 이미지 2/2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Battery Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Battery Replacement: 2 단계, 이미지 2/2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: 3 단계, 이미지 1/3 Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: 3 단계, 이미지 2/3 Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Battery Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Battery Replacement: 4 단계, 이미지 2/2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Battery Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab 3 10.1 Battery Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab 3 10.1 Battery Replacement: 5 단계, 이미지 3/3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Battery Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Battery Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Battery Replacement: 7 단계, 이미지 2/2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Battery Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Battery Replacement: 8 단계, 이미지 2/2
    • Lift with a nylon spudger to remove the battery.
결론
다른 75명이 해당 안내서를 완성하였습니다.
Corey Brown
회원 가입일: 06/24/16
8,826 평판
안내서 11개 작성하였습니다
댓글 7개
Great, Thanks for the help. It was very useful.
nyhorseracing - 답글
why are there white lines all over the screen after a new battery was installed
Rosita Fowler - 답글
brilliant ! worked extremely well !
Carmelo Aquilina - 답글
Thank you very much for the information. I have one question, though. The new battery works, but it takes a VERY long time to charge. More than a day, in fact. Any idea what could be causing that? Is it possible that one of the connections is not tight enough? If so, which connection might that be?
Thank you.
Paul Ross - 답글
Very easy instructions. Thank you. My only snag was that the ten screws holding the battery were extremely reluctant to undo. wrecked the IFxit screw driver. Fortunately, I had another one. My tip for anyone doing this little job, is to use quit a lot of downward pressure on the screws. Turn them 1/4 turn anticlockwise and back again. Do this several times until they turn freely. You will then have an easy job. I will replace those screws with a tiny blob of 'Never Seize'.
Keith Aldworth - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 44
30일 전: 263
전체 시간: 43,547
