주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 10.1 LED Light Replacement
필요한 것
  1. Samsung Galaxy Tab 3 10.1 LED Light Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 LED Light Replacement, Rear Case: 1 단계, 이미지 2/2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 LED Light Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 LED Light Replacement: 2 단계, 이미지 2/2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 LED Light Replacement, LED Light: 3 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 LED Light Replacement, LED Light: 3 단계, 이미지 2/2
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  4. Samsung Galaxy Tab 3 10.1 LED Light Replacement: 4 단계, 이미지 1/1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  5. Samsung Galaxy Tab 3 10.1 LED Light Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab 3 10.1 LED Light Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab 3 10.1 LED Light Replacement: 5 단계, 이미지 3/3
    • Use the flat end of the spudger to flip up the press-fit connector attaching the LED to the motherboard.
    • Remove the LED indicator light by gently pulling upward with nylon-tipped tweezers.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Corey Brown
회원 가입일: 06/24/16
8,072 평판
안내서 11개 작성하였습니다
댓글 한 개
Above article is useful for removing LED Light.
Which LED are we removing - Camera Flash or screen display LED?
How to fit new LED Light?
Please reply. I am facing issues with screen display and flash for camera is also not working
Ashwini Dughad - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 44
전체 시간: 3,945
