주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 10.1 Motherboard Replacement
필요한 것
  1. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: 1 단계, 이미지 2/2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 2 단계, 이미지 2/2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: 3 단계, 이미지 1/3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: 3 단계, 이미지 2/3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: 3 단계, 이미지 3/3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 4 단계, 이미지 2/2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 7 단계, 이미지 2/2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 8 단계, 이미지 2/2
    • Lift with a nylon spudger to remove the battery.
  9. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  10. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 10 단계, 이미지 1/1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  11. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 11 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the 3mm screw attaching the motherboard to the display chassis.
  12. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 12 단계, 이미지 1/3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 12 단계, 이미지 2/3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 12 단계, 이미지 3/3
    • Use a nylon spudger to flip up the eight press-fit connectors from the motherboard.
    • The vibration motor is missing from these photos.
  13. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 13 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 13 단계, 이미지 2/2
    • Use nylon-tipped tweezers to remove the motherboard.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Corey Brown
회원 가입일: 06/24/16
8,072 평판
안내서 11개 작성하였습니다
3 댓글
Great guide, project completed.
Edgar Merced - 답글
Simplemente GENIAL!!!!
Muy claro.
Felicitaciones.
Cuenten con mis aportes al foro
Ahora que pude retirar placa base voy a ver esquemático, porque WIFI se desactiva . No funciona.
Saludos
DARIO GASTAUDO - 답글
very easy to destroy the Galaxy. finicky to the max!
ein Stein - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 60
전체 시간: 8,947
