주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 10.1 Motherboard Replacement
필요한 것
  1. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: 1 단계, 이미지 2/2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
    I would not remove the back of the case. There are around 14 tabs inside that are melted down to secure the frame. Those melted tabs will break off and the back won't be as secure and the edge of the back will have have a visible gap showing. I would remove the case from the screen side as in step 5 of this tear down and use a iFixit opening tool. Use the tool with handle towards the screen to pry the frame away. Start on one long edge and slide the tool along the gap and at same time slightly pry the case away. Then separate a short edge. The corner between the 2 open gaps should just pop away with some prying. Do the same with other 2 edges and corner.
    Gary L. Turner - 답글
    Kommentar von Gary L. Turner bestätigt. Es geht eindeutig besser das Opening Tool in den Spalt an der Oberseite einzuführen, zwischen dem umlaufenden silberfarbenen Rahmen und dem Display Glas. Die im Foto oben unter Schrott 1 gezeigte Methode ist NICHT zerstörungsfrei. Das (weisse) Back cover und der umlaufende silberfarbene Rahmen sind zwei separate Kunststoff-Bauteile, die an ca. einem Dutzend Punkten miteinander verschweisst sind, und zwar so eng dass kein Fingernagel dazwischen passt. Diese Schweisspunkte zerbrechen bei der im Bild oben gezeigten Methode.
    Ralf Hanisch - 답글
    sry, “Schritt 1” muss es natürlich heissen, nicht “Schrott 1” ;-)
    Ralf Hanisch -
    Use the iFixIt Opener. You’ll have to find a large opening, seems like near a piece of tech is easier. Once you get a firm and deep opening, keep working it down.
    Shane - 답글
    Bitte aufpassen: Dies ist NICHT die Anleitung, um den Akku beim TAB S3 zu ersetzen, dies wird an anderer Stelle beschrieben, leider auf Englisch.
    Aber beim S-3 ist es viel schwieriger, da beim S-3 auch das Frontglas entfernt werden muß…..
    klement, herbert - 답글
  2. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 2 단계, 이미지 2/2
    • Lift the case up to remove it.
    Be careful around the camera if it sticks, use spudger to separate.
    Shane - 답글
  3. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: 3 단계, 이미지 1/3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: 3 단계, 이미지 2/3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: 3 단계, 이미지 3/3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
    Remove green tape over connectors, you can put back on later if it still is sticky enough.
    Shane - 답글
    I want to purchase a tab 3 replacement battery T4500E 6800mah, should I also include the S/N number mine is TL1F109AS/9-B (CANNOT FIND A MATCH ONLINE )please help does this number really matter when making the purchase?
    Shavonise Ricketts - 답글
    No batteries available online
    Anton Berggren - 답글
  4. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 4 단계, 이미지 2/2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
    Um die winzigen Schraubenköpfe zu schonen verwende grundsätzlich den grösstmöglichen (und nicht den kleinstmöglichen!) Schraubendreher. Für die zehn Kreuzschlitzschrauben mit denen der Akku befestigt ist passt ein Philips #0 perfekt.
    Ralf Hanisch - 답글
    Nachtrag: Philips #00 passt fast noch besser.
    Ralf Hanisch -
  7. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 7 단계, 이미지 2/2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
    It seems like prying underneath the cords is better and won’t damage the motherboard’s black connector piece.
    Shane - 답글
  8. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 8 단계, 이미지 2/2
    • Lift with a nylon spudger to remove the battery.
  9. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  10. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 10 단계, 이미지 1/1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  11. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 11 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the 3mm screw attaching the motherboard to the display chassis.
  12. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 12 단계, 이미지 1/3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 12 단계, 이미지 2/3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 12 단계, 이미지 3/3
    • Use a nylon spudger to flip up the eight press-fit connectors from the motherboard.
    • The vibration motor is missing from these photos.
    How can I get these two metal jackets on the right off?
    Nikou - 답글
  13. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 13 단계, 이미지 1/2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 13 단계, 이미지 2/2
    • Use nylon-tipped tweezers to remove the motherboard.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Corey Brown
회원 가입일: 06/24/16
8,679 평판
안내서 11개 작성하였습니다
댓글 3개
Great guide, project completed.
Edgar Merced - 답글
Simplemente GENIAL!!!!
Muy claro.
Felicitaciones.
Cuenten con mis aportes al foro
Ahora que pude retirar placa base voy a ver esquemático, porque WIFI se desactiva . No funciona.
Saludos
DARIO GASTAUDO - 답글
very easy to destroy the Galaxy. finicky to the max!
ein Stein - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 48
전체 시간: 9,618
