주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • With a plastic opening tool, gently insert the prying end in between the glass digitizer and the silver frame from the front of the device.
  2. Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement: 2 단계, 이미지 3개 중 3개
    • Working slowly and carefully, move around the entirety of the face of the device. Small plastic clips should release, if not, apply gentle outwards pressure until you hear the clips popping off.
  3. Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • To begin actual removal of the battery itself, remove the four designated screws with your screwdriver.
    • Once the screws are removed, use either the tip of your screwdriver or a pair of tweezers to pull up the battery connector. Pull directly up and the connector should pop out.
    • Once the battery is removed, it should look as it does in the third picture.
  4. Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement: 4 단계, 이미지 1개 중 1개
    • To finish battery replacement, place your new battery where the old battery was in your device, as shown in the picture.
  5. Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Begin replacement of the motherboard by releasing all connections holding down the motherboard, shown in the first picture.
    • To do this, use your spudger, tweezers, or a plastic opening tool and gently lift the connections up from their ports.
    • Once you separate all connections, the back of your device should look as it does in the third picture.
  6. Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement: 6 단계, 이미지 3개 중 3개
    • Once all connections have been released, begin removing the screws shown in the first two pictures.
    • Once all screws have been removed, the motherboard can now be removed and replaced with a new one.
  7. Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement, Headphone Jack: 7 단계, 이미지 3개 중 1개 Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement, Headphone Jack: 7 단계, 이미지 3개 중 2개 Samsung Galaxy Tab 3 7.0 Headphone Jack Replacement, Headphone Jack: 7 단계, 이미지 3개 중 3개
    • To remove the headphone jack, begin by removing the two designated screws shown in the first picture.
    • Once the screws have been removed, the headphone jack can simply be lifted from the device.
    • After this step is complete, a replacement headphone jack can be placed into the device where the old headphone jack was, as shown in the third picture.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Brandon Dimaya
회원 가입일: 04/22/14
2,866 평판
안내서 4개를 작성함
Cal Poly, Team 7-20, Regan Spring 2014 Cal Poly, Team 7-20, Regan Spring 2014 회원
CPSU-REGAN-S14S7G20
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 16,562
