주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 8.0 Battery Replacement
필요한 것
  1. Samsung Galaxy Tab 3 8.0 Battery Replacement, Battery - Open up the tablet: 1 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Battery Replacement, Battery - Open up the tablet: 1 단계, 이미지 2/2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Battery Replacement, Remove Back Cover: 2 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Battery Replacement, Remove Back Cover: 2 단계, 이미지 2/2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Battery Replacement, Disconnect Battery: 3 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Battery Replacement, Disconnect Battery: 3 단계, 이미지 2/2
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Battery Replacement, Remove Battery: 4 단계, 이미지 1/1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
결론
다른 32명이 해당 안내서를 완성하였습니다.
Peter Paoletta
회원 가입일: 09/22/14
2,085 평판
안내서 3개 작성하였습니다
USF Tampa, Team 4-2, Brown Fall 2014 USF Tampa, Team 4-2, Brown Fall 2014 회원
USFT-BROWN-F14S4G2
3 회원들
안내서 26개 작성하였습니다
댓글 2개
To remove the battery without risk of damage, slide the corner of an old credit card under the battery in the middle at the end opposite the connector, then slide the card down under the battery to seperate the battery from the adhesive underneath. Repeat on the other side.
Hector McGillivray - 답글
Also be REALLY careful when lifting up on the battery connector. It can tear away from the motherboard easily.
Lori Beth Kerns - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 52
전체 시간: 39,438
