소개
If your tablet has a broken touch screen glass (digitizer), LCD display or you want to chang the micro USB charging port, loudspeakers, audio jack connector, etc., with this guide we will help you to do it.
필요한 것
동영상 개요
Put the scotch tape in order not to scatter pieces of glass.
Remove any memory card and SIM card (if the tablet is 3G version).
Remove the two screws and disconnect the charging port flex cable from the main board.
Use a plastic tool to unstick the flex cable from the middle frame.
다른 18명이 해당 안내서를 완성하였습니다.
댓글 한 개
Awesome guide, was so easy to replace complete LCD digitiser and glass all in one unit.
capinneemo - 답글
