주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: 1 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: 1 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: 1 단계, 이미지 3/3
    • Put the scotch tape in order not to scatter pieces of glass.
    • Remove any memory card and SIM card (if the tablet is 3G version).
  2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: 2 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: 2 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: 2 단계, 이미지 3/3
    • Using plastic tools remove the back / battery cover.
    • Be careful with the Power and Volume buttons.
  3. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 3 단계, 이미지 1/1
    • Before doing anything, disconnect the battery.
  4. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: 4 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: 4 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: 4 단계, 이미지 3/3
    • This step is only if you want to replace the micro USB port flex cable.
    • Remove the two screws and disconnect the charging port flex cable from the main board.
    • Use a plastic tool to unstick the flex cable from the middle frame.
  5. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: 5 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: 5 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: 5 단계, 이미지 3/3
    • This step is for only if you want to change the battery.
    • The battery is stuck to the middle panel.
    • Use the white sticker to remove it.
  6. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: 6 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: 6 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: 6 단계, 이미지 3/3
    • 2x loudspeackers
    • Power & Volume buttons flex cable
    • Audio jack flex cable
  7. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 2: 7 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 2: 7 단계, 이미지 2/2
    • Front camera
    • Wi-Fi antenna
  8. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 8 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 8 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 8 단계, 이미지 3/3
    • Use a heat gun or hair dryer and warm the touch screen glass. This will make the adhesive more flexible and the separation easier.
    • Use a gloves to avoid any injurys from glass.
    • Do not rush.
  9. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 9 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 9 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 9 단계, 이미지 3/3
    • Beware for the menu buttons flex cable.
  10. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 10 단계, 이미지 2/2
    • Always test the new spare part before final installation.
  11. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 11 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 11 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 11 단계, 이미지 3/3
    • Transfer the black tape from the old display. It keeps the distance the display from the battery and protects it from overheat.
    • If the adhesive tape is not in good condition you must install a new one.
  12. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 12 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 12 단계, 이미지 2/2
    • Start with reassembling.
    • Did you do it successfully.
결론
다른 18명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,278 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 한 개
Awesome guide, was so easy to replace complete LCD digitiser and glass all in one unit.
capinneemo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 20
전체 시간: 25,170
