소개
This guide will take you through the step-by-step process of removing and replacing the motherboard of a Samsung Galaxy Tab 3 8.0.
필요한 것
Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
After the battery is disconnected, use the pulling tab to safely remove the battery.
Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver, then lift the speakers from the device.
Using a plastic remover tool, carefully unseat each of the electric leads plugged into the board.
Unscrew the 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery.
다른 12명이 해당 안내서를 완성하였습니다.
2 댓글
You don’t need to remove the battery in order to remove the motherboard. Just disconnect the battery!
