주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 8.0 Motherboard Replacement
필요한 것
  1. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Battery - Open up the tablet: 1 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Battery - Open up the tablet: 1 단계, 이미지 2/2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove Back Cover: 2 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove Back Cover: 2 단계, 이미지 2/2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect Battery: 3 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect Battery: 3 단계, 이미지 2/2
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove Battery: 4 단계, 이미지 1/1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect Speakers: 5 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect Speakers: 5 단계, 이미지 2/2
    • Disconnect the relays attached to the motherboard.
  6. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Speakers: 6 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Speakers: 6 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Speakers: 6 단계, 이미지 3/3
    • Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver, then lift the speakers from the device.
  7. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect All Relays: 7 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect All Relays: 7 단계, 이미지 2/2
    • Using a plastic remover tool, carefully unseat each of the electric leads plugged into the board.
  8. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Motherboard: 8 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Motherboard: 8 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Motherboard: 8 단계, 이미지 3/3
    • Unscrew the 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery.
  9. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove the Motherboard: 9 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove the Motherboard: 9 단계, 이미지 2/2
    • Carefully lift the board from the device.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Kyle Ballard
회원 가입일: 09/22/14
939 평판
안내서 2개 작성하였습니다
USF Tampa, Team 4-2, Brown Fall 2014 USF Tampa, Team 4-2, Brown Fall 2014 회원
USFT-BROWN-F14S4G2
3 회원들
안내서 26개 작성하였습니다
댓글 2개
Be sure to include screw lengths to the nearest mm on all repair guides.
Dan Brown - 답글
You don’t need to remove the battery in order to remove the motherboard. Just disconnect the battery!
matt greece - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 20
전체 시간: 10,945
