주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 8.0 Rear Camera Replacement
필요한 것
  1. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Battery - Open up the tablet: 1 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Battery - Open up the tablet: 1 단계, 이미지 2/2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove Back Cover: 2 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove Back Cover: 2 단계, 이미지 2/2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect Battery: 3 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect Battery: 3 단계, 이미지 2/2
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove Battery: 4 단계, 이미지 1/1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect Speakers: 5 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect Speakers: 5 단계, 이미지 2/2
    • Disconnect the relays attached to the motherboard.
  6. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Speakers: 6 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Speakers: 6 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Speakers: 6 단계, 이미지 3/3
    • Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver, then lift the speakers from the device.
  7. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect All Relays: 7 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect All Relays: 7 단계, 이미지 2/2
    • Using a plastic remover tool, carefully unseat each of the electric leads plugged into the board.
  8. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Motherboard: 8 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Motherboard: 8 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Motherboard: 8 단계, 이미지 3/3
    • Unscrew the 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery.
  9. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove the Motherboard: 9 단계, 이미지 1/2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove the Motherboard: 9 단계, 이미지 2/2
    • Carefully lift the board from the device.
  10. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect the Rear Camera: 10 단계, 이미지 1/3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect the Rear Camera: 10 단계, 이미지 2/3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect the Rear Camera: 10 단계, 이미지 3/3
    • Flip the motherboard to reveal the rear camera connection and with tweezers gently lift the connector pins and remove the camera.
결론
다른 4명이 해당 안내서를 완성하였습니다.
anthony gonzalez
회원 가입일: 09/22/14
313 평판
안내서 3개 작성하였습니다
USF Tampa, Team 4-2, Brown Fall 2014 USF Tampa, Team 4-2, Brown Fall 2014 회원
USFT-BROWN-F14S4G2
3 회원들
안내서 26개 작성하였습니다
댓글 한 개
That worked a treat, thanks a lot Anthony, I don’t quite know when I broke my rear camera but I suspect it’s after being dropped, unfortunatly more than once, a replacement camera was sourced from ebay and only cost £3.29 that included the postage! So all is well again now.
Here’s a link to where I bought mine, I can recommend them 100%
https://www.ebay.co.uk/itm/Genuine-Rear-...
Once again, Cheers!
mooog1 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 1,270
