주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 Kids Camera Replacement
필요한 것
  1. Samsung Galaxy Tab 3 Kids Camera Replacement, Camera: 1 단계, 이미지 1/2 Samsung Galaxy Tab 3 Kids Camera Replacement, Camera: 1 단계, 이미지 2/2
    • Using the plastic opening tool to open up the device, wedge in the seam between the screen and the back cover. Slide the tool around all the edges and remove the screen from the back cover
  2. Samsung Galaxy Tab 3 Kids Camera Replacement: 2 단계, 이미지 1/1
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids Camera Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Tab 3 Kids Camera Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Tab 3 Kids Camera Replacement: 3 단계, 이미지 3/3
    • Before Changing the motherboard, you have to lift up the (ZIF) zero insertion force by using the plastic opening tool, separating the connector from the batter ribbon cable
  4. Samsung Galaxy Tab 3 Kids Camera Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab 3 Kids Camera Replacement: 4 단계, 이미지 2/2
    • Unscrew the ten 4mm PH000 bolts holding the motherboard on the device
  5. Samsung Galaxy Tab 3 Kids Camera Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab 3 Kids Camera Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab 3 Kids Camera Replacement: 5 단계, 이미지 3/3
    • Remove the mother board from the device by carefully lifting it out.
  6. Samsung Galaxy Tab 3 Kids Camera Replacement: 6 단계, 이미지 1/3 Samsung Galaxy Tab 3 Kids Camera Replacement: 6 단계, 이미지 2/3 Samsung Galaxy Tab 3 Kids Camera Replacement: 6 단계, 이미지 3/3
    • Remove camera by carefully lifting out of the device
결론
다른 2명이 해당 안내서를 완성하였습니다.
ajhoffman
회원 가입일: 01/04/14
182 평판
안내서 5개 작성하였습니다
USF Tampa, Team 2-6, Nance Fall 2016 USF Tampa, Team 2-6, Nance Fall 2016 회원
USFT-NANCE-F16S2G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 215
