주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 Kids Motherboard Replacement
필요한 것
  1. Samsung Galaxy Tab 3 Kids Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Samsung Galaxy Tab 3 Kids Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Wedge the plastic opening tool in the seam between the screen and the back cover.
    • Slide the tool around all the edges and remove the screen from the back cover.
  2. Samsung Galaxy Tab 3 Kids Motherboard Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab 3 Kids Motherboard Replacement: 2 단계, 이미지 2/2
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids Motherboard Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Tab 3 Kids Motherboard Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Tab 3 Kids Motherboard Replacement: 3 단계, 이미지 3/3
    • Disconnect all the flex cables from the motherboard by prying the connectors straight up.
  4. Samsung Galaxy Tab 3 Kids Motherboard Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab 3 Kids Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the ten 4 mm Phillips #000 screws securing the motherboard.
  5. Samsung Galaxy Tab 3 Kids Motherboard Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab 3 Kids Motherboard Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab 3 Kids Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the motherboard from the device by carefully lifting it out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
ajhoffman
회원 가입일: 01/04/14
182 평판
안내서 5개 작성하였습니다
USF Tampa, Team 2-6, Nance Fall 2016 USF Tampa, Team 2-6, Nance Fall 2016 회원
USFT-NANCE-F16S2G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 940
