주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement
필요한 것
  1. Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement, Rear Case: 1 단계, 이미지 3/3
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
    • This is a long process, so don't try and rush it. Also, be careful about applying pressure.
  2. Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement: 2 단계, 이미지 3/3
    • After separating the tape holding the screen and case together, slowly start taking the screen off the case from the opposite side of the side with the buttons
  3. Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement, Motherboard: 3 단계, 이미지 1/3 Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement, Motherboard: 3 단계, 이미지 2/3 Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement, Motherboard: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a plastic opening tool to lift up the zero insertion force (ZIF) connector holding down the ribbon cable.
    • Use the precision tweezers to gently pull the ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool to lift up the zero insertion force (ZIF) connector holding down the battery ribbon cable.
    • Use the precision tweezers to remove the ribbon cable from the ZIF connector.
  5. Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement: 5 단계, 이미지 2/2
  6. Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement: 6 단계, 이미지 1/1
    • Remove the seven 4mm Phillips J000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement: 7 단계, 이미지 1/1
    • Use the plastic opening tool and gently pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement: 8 단계, 이미지 1/3 Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement: 8 단계, 이미지 2/3 Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement: 8 단계, 이미지 3/3
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard off the case.
  9. Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement, LCD and Digitizer: 9 단계, 이미지 1/3 Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement, LCD and Digitizer: 9 단계, 이미지 2/3 Samsung Galaxy Tab 3 Lite LCD and Digitizer Replacement, LCD and Digitizer: 9 단계, 이미지 3/3
    • With the motherboard removed, continue by removing the battery
    • Using the plastic opening tool, put it between one of the corners of the battery and the edge and gently pry it out
    • Battery is now removed. What is left is the entire LCD and Digitizer
결론
다른 24명이 해당 안내서를 완성하였습니다.
Patricia Laird
회원 가입일: 02/09/16
927 평판
안내서 4개 작성하였습니다
USF Tampa, Team 11-1, Cheng Spring 2016 USF Tampa, Team 11-1, Cheng Spring 2016 회원
USFT-CHENG-S16S11G1
4 회원들
안내서 12개 작성하였습니다
댓글 6개
I completed this tonight.
One place I would express a little more care is when working around the front button. I tore the back of the button slightly when I was removing the digitizer.
Question: what is best for removing the adhesive around the frame? I was using what was on hand (valve oil for a trumpet). It worked but the adhesive should of come off without so much effort. A lot more scarping. I have used Goo Gone before but it seems very messy.
This was the third android tablet I have replaced a screen and or digitizer before (all Galaxy Tabs).
Thank you for the guide.
George Tedrick - 답글
Thank you for the best guide! !
allwin2abbas - 답글
Wonderful Guide!!! Very easy to follow!! Adhesive was a thorn though~!~ :-)
apriltanner1975 - 답글
Nesse caso será trocado todo o quadro com sensor de toque e display? No caso de trocar separadamente o sensor de toque e display, qual adesivo recomendam? Obrigado
Amaury Souza - 답글
Readme before task:
Before separating the glass… make note of exactly how the front aligns(overhangs) the frame, there's nothing to guide it back except your own steady hand.
Also: when prying the front glass, it will shatter and pelt you with shards and dust. Put tape over it before starting.
It's not clear in the article… the LCD sits in the frame and isn't attached to the digitizer/front glass. This means to replace glass, no need to buy LCD, or remove motherboard or battery.
I reassembled the outer case without using tape, it seems pretty secure and snapped into place satisfyingly.
sparkycivic - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 36
전체 시간: 18,056
