소개
This guide will show you how to replace the speaker on the Samsung Galaxy Tab 3 Lite. Before doing this, you'll need to remove the back case of your tablet. You will then be able to proceed to replace the speaker.
필요한 것
Using a plastic opening tool, wedge in the seam between the screen and the case.
Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
This is a long process, so don't try and rush it. Also, be careful about applying pressure.
Use one of the plastic opening tools and place it somewhat firmly on one of the two openings in the plastic around the speaker.
Apply pressure and pry the speaker out of its seat. The speaker should just pop out.
다른 8명이 해당 안내서를 완성하였습니다.
