주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 Lite Speaker Replacement
필요한 것
  1. Samsung Galaxy Tab 3 Lite Speaker Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung Galaxy Tab 3 Lite Speaker Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung Galaxy Tab 3 Lite Speaker Replacement, Rear Case: 1 단계, 이미지 3/3
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
    • This is a long process, so don't try and rush it. Also, be careful about applying pressure.
  2. Samsung Galaxy Tab 3 Lite Speaker Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Tab 3 Lite Speaker Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Tab 3 Lite Speaker Replacement: 2 단계, 이미지 3/3
    • After separating the tape holding the screen and case together, slowly start taking the screen off the case from the opposite side of the side with the buttons
  3. Samsung Galaxy Tab 3 Lite Speaker Replacement, Speaker: 3 단계, 이미지 1/3 Samsung Galaxy Tab 3 Lite Speaker Replacement, Speaker: 3 단계, 이미지 2/3 Samsung Galaxy Tab 3 Lite Speaker Replacement, Speaker: 3 단계, 이미지 3/3
    • Use one of the plastic opening tools and place it somewhat firmly on one of the two openings in the plastic around the speaker.
    • Apply pressure and pry the speaker out of its seat. The speaker should just pop out.
  4. Samsung Galaxy Tab 3 Lite Speaker Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Tab 3 Lite Speaker Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Tab 3 Lite Speaker Replacement: 4 단계, 이미지 3/3
    • Using a spudger, carefully pry up the speaker ribbon cable.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Patricia Laird
회원 가입일: 02/09/16
924 평판
안내서 4개 작성하였습니다
USF Tampa, Team 11-1, Cheng Spring 2016 USF Tampa, Team 11-1, Cheng Spring 2016 회원
USFT-CHENG-S16S11G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 1,201
