주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 Password Lock/Hard Reset
동영상 개요
  1. Samsung Galaxy Tab 3 Password Lock/Hard Reset, Power Off: 1 단계, 이미지 1/2 Samsung Galaxy Tab 3 Password Lock/Hard Reset, Power Off: 1 단계, 이미지 2/2
    • Power off the tablet by pressing and holding the Power Lock button. The Tablet Options menu will appear.
    • Select the ‘Power Off’ option.
    • Touch ‘OK’ and the tablet will power off.
  2. Samsung Galaxy Tab 3 Password Lock/Hard Reset: 2 단계, 이미지 1/3 Samsung Galaxy Tab 3 Password Lock/Hard Reset: 2 단계, 이미지 2/3 Samsung Galaxy Tab 3 Password Lock/Hard Reset: 2 단계, 이미지 3/3
    • Press and hold the Home button, the Volume Up bottom, and the Power button simultaneously.
    • When the Samsung Galaxy Tab 3 logo appears, release only the Power button, keeping the Home button and Volume Up button pressed. You are now viewing the Android Recovery Menu.
  3. Samsung Galaxy Tab 3 Password Lock/Hard Reset: 3 단계, 이미지 1/3 Samsung Galaxy Tab 3 Password Lock/Hard Reset: 3 단계, 이미지 2/3 Samsung Galaxy Tab 3 Password Lock/Hard Reset: 3 단계, 이미지 3/3
    • Use the Volume Up/Volume Down buttons to scroll through the Recovery Menu and the Power button to select options.
    • Select ‘Wipe data/factory reset.’
    • Select ‘Yes - erase all user data.’
    • Select ‘reboot system now.’
결승점
다른 192명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,278 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 110개
thank you so much i have been locked out of my tablet for months now
zeidi - 답글
Il existe de nombreuses raisons pour mot de passe oublié tablette samsung, ainsi que de nombreuses méthodes différentes, mais vous voudrez peut-être qu'un tiers déverrouille votre téléphone, car il s'agit du moyen le plus simple, le plus rapide et le plus simple pour faire le travail. .
Jakcoaio -
for ALL that come here READ this: scroll up to under the video and click “video source”. This takes you to original on youtube. Good. Now scroll down below the vid to the description. Click on “show more”. READ. It explains very specifically near the end. I was not having success until I read and did, Viola!! It worked. I personally screen shot it to save to my other info for this device. Thought I would come back here to tell others that come here one day in the future what i found and can get it and not end up being frustrated. Good luck to all. The original poster here should have mentioned to seek out the original video. Bogus!!! “Fixit” did a terrible job.
Barb Smith -
Hi - I have tried this but it won't let me highlight the wipe data / factory reset line. It skips from the one above to the one below ... help??
Sandra - 답글
Then you select the factory reset line with volume button, you press smoothly the power on button .
Kannan -
댓글 쓰기
조회 통계:
24 시간 전: 29
7일 전: 193
30일 전: 866
전체 시간: 837,244
