주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 Volume Buttons Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Samsung Galaxy Tab 3 Volume Buttons Replacement, Open Device: 1 단계, 이미지 1/1
    • Using your plastic opening tools, carefully start to pry apart your Samsung Galaxy Tab 3 10.1 all along the edge. Do this until the back side of the tablet can be removed.
    • Be careful when inserting the opening tools to avoid damaging the speakers on left and right sides. The picture actually show a dangerous position for the right (small) opening tool.
    • During reassembly, be careful not to insert bottom, left, nor right edges first—doing so can damage the power button, and prevent the front panel from sitting totally flush.
    • If screen is cracked like shown imagine, Place tape on screen to prevent injury.
  2. Samsung Galaxy Tab 3 Volume Buttons Replacement, Ribbon Cables: 2 단계, 이미지 1/1
    • Gently remove tape over ribbon cable connectors and set it to the side. Using the opening tools, gently lift the connector latches to disconnect the ribbon cables.
  3. Samsung Galaxy Tab 3 Volume Buttons Replacement, Battery Screws: 3 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the ten screws securing the battery to the motherboard.
    • Make sure to keep screws in a secure location for reassembly.
  4. Samsung Galaxy Tab 3 Volume Buttons Replacement, Removal: 4 단계, 이미지 1/1
    • Pull back the ribbon cables, lift up the original battery, and disconnect the battery by exerting upward pressure from beneath the battery.
  5. Samsung Galaxy Tab 3 Volume Buttons Replacement, Remove volume buttons from motherboard: 5 단계, 이미지 1/1
    • Using the plastic opening tool, gently detach the volume buttons cable from the motherboard by prying its connector upward.
  6. Samsung Galaxy Tab 3 Volume Buttons Replacement, Remove volume buttons from framework: 6 단계, 이미지 1/1
    • Insert the plastic opening tool in between the volume buttons and the inner framework. Gently slide the opening tool to the left, releasing the volume buttons from the framework.
  7. Samsung Galaxy Tab 3 Volume Buttons Replacement, Replace buttons: 7 단계, 이미지 1/1
    • Gently remove the faulty buttons and insert new buttons. Be sure to properly attach the buttons to the motherboard via its cable.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Tyler Oliver
회원 가입일: 10/31/14
227 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-2, Duarte Fall 2014 UMass Dartmouth, Team 2-2, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G2
4 회원들
안내서 6개 작성하였습니다
댓글 2개
I have the Samsung galaxy tab 3 kids edition, had to do this repair once already (about a year ago, one year into use) and now the buttons have busted again... Going to pry the back off to jiggle the ribbon cable and hopefully get a boot up past the battery charging screen... For a kids product you'd think they'd make the tactile buttons durable... They're crap... I even have the official chunky ugly handle case covering the buttons in a jelly case material... Rubbish! Planning on finding a mod that allows booting from the home button... Or automatic boot from battery charging screen... At least then I'll be life proofed against crappy design... This toy should be relavant until my daughter is at least 9 or something and wants something grown up and that has the latest power kick... She's 2.5 and is peeved she can't watch kung fu panda... And now I'm peeved because of course she's made me put it on the TV.... We watched that film like yesterday... 1st world problems...
Charles Stawell - 답글
Update:
Decided in the end to install TWRP custom recovery and root, i added a mod to the playlpm file in /system/bin to make the tablet boot when it its plugged in for 20 seconds... Now I'm guarded against needing the power and volume rockers... (Twrp recovery is fully touch friendly)
Manages to get power button working for now... But it's going to fail again... And now at least I won't be permanently locked out until i stick a replacement flex cable in...
Charles Stawell -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 20
전체 시간: 14,464
