이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
Peel off the green tape that covers the connectors for the three black strips.
Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
Remove the two 2.7mm Phillips #00 screws from the micro USB port.
Remove the micro USB retaining bracket.
Use the flat end of a spudger to disconnect the micro USB port.
Remove the micro USB port.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 2개
Thank you so much for simplifying this guide for us novices. I have tried watching two videos where they assume I already have some Samsung repair knowledge. I feel confident I will be able to get the tablet up and charging in no time.
There is no need to remove the battery, only detach the power connector, cheers!
