주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 4 10.1 Motherboard Replacement
필요한 것
  1. Samsung Galaxy Tab 4 10.1 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Samsung Galaxy Tab 4 10.1 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Motherboard Replacement: 2 단계, 이미지 1/1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Motherboard Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Motherboard Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 Motherboard Replacement: 5 단계, 이미지 1/1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Motherboard Replacement: 6 단계, 이미지 1/1
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 Motherboard Replacement, Motherboard: 7 단계, 이미지 1/2 Samsung Galaxy Tab 4 10.1 Motherboard Replacement, Motherboard: 7 단계, 이미지 2/2
    • Remove the two 2.7mm Phillips #00 screws from the motherboard.
  8. Samsung Galaxy Tab 4 10.1 Motherboard Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Tab 4 10.1 Motherboard Replacement: 8 단계, 이미지 2/2
    • Use the flat end of a spudger to pry up and disconnect the five press-fit connectors from the motherboard.
  9. Samsung Galaxy Tab 4 10.1 Motherboard Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Tab 4 10.1 Motherboard Replacement: 9 단계, 이미지 2/2
    • Use a spudger to pry up the motherboard, and remove it from the device.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Blake Klein
회원 가입일: 01/29/17
70,919 평판
안내서 50개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 25
전체 시간: 4,249
