주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 4 7.0 Battery Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Battery Replacement: 2 단계, 이미지 1/1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: 3 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: 3 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: 3 단계, 이미지 3/3
    • You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
    • Work the spudger underneath the battery as shown and pry the battery away from the phone case.
    • The battery is attached to the case with adhesive, so a bit of force is required during removal.
결론
다른 28명이 해당 안내서를 완성하였습니다.
Edgard R Baladron
회원 가입일: 08/31/15
432 평판
안내서 1개 작성함
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G3
4 회원들
안내서 12개 작성하였습니다
댓글 3개
This is for a cell phone, not a tablet. Why?
ckmjunk - 답글
it is the tablet
sourcandysaiyan -
OH! its so easy!! woohoo, ordering battery now!
sourcandysaiyan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 49
전체 시간: 26,713
