주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 4 7.0 Camera Replacement
필요한 것
  1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: 1 단계, 이미지 2/2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Camera Replacement: 2 단계, 이미지 1/1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: 3 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: 3 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: 3 단계, 이미지 3/3
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Camera Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Camera Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Camera Replacement: 4 단계, 이미지 3/3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Camera Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Camera Replacement: 5 단계, 이미지 2/2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Camera Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Camera Replacement: 6 단계, 이미지 2/2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
    Use caution taking the board out as it does have some tabs that may hold it in place
    Andrew - 답글
  7. Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: 7 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: 7 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: 7 단계, 이미지 3/3
    • With the tweezers grab the base of the wire harness and slide it outward in the direction shown.
    • This can be done for either camera on the tablet.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Aubrey Goodwin
회원 가입일: 08/31/15
2,700 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G3
4 회원들
안내서 12개 작성하였습니다
댓글 3개
My camera on the Tab 4 is fine, but the len on the back is scratched. Can I get a replacement for the lens? If so where can I purchase this and is it comparable with other Tabs or Cells lens. I am not looking for a camera, Im look for the glass that protects the said camera.
Amanda Ellenberger - 답글
पॉप आर्ट मुझे चाहिये
Jagdish Mote - 답글
टॅब पार्ट खरेदी करना है मुझको
Jagdish Mote - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 15
전체 시간: 4,278
