주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 4 7.0 Motherboard Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: 1 단계, 이미지 2/2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 2 단계, 이미지 1/1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: 3 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: 3 단계, 이미지 3/3
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 4 단계, 이미지 3/3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 5 단계, 이미지 2/2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: 6 단계, 이미지 2/2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
    Use caution taking the board out as it does have some tabs that may hold it in place
    Andrew - 답글
결론
다른 24명이 해당 안내서를 완성하였습니다.
Briana Honeycutt
회원 가입일: 08/31/15
432 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G3
4 회원들
안내서 12개 작성하였습니다
댓글 4개
I would like to change my tab 4 motherboard as ic heated so what is the price of new board
Malik - 답글
Do the replacement motherboards sold on ifixit come with the operating system installed or do you have to install a new operating system once you replace the motherboard?
Erich Reichard - 답글
Good instructions but not complete. My replacement motherboard was delivered without the cameras. I had to remove the cameras from the old motherboard and install them in the new motherboard. Then install the new motherboard.
Richard Kaapuni - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 49
전체 시간: 18,029
