주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 4 7.0 Screen Replacement
필요한 것
  1. Samsung Galaxy Tab 4 7.0 Screen Replacement, Back Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Screen Replacement, Back Panel: 1 단계, 이미지 2/2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Screen Replacement: 2 단계, 이미지 1/1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Screen Replacement, Motherboard: 3 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Screen Replacement, Motherboard: 3 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Screen Replacement, Motherboard: 3 단계, 이미지 3/3
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Screen Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Screen Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Screen Replacement: 4 단계, 이미지 3/3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Screen Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Screen Replacement: 5 단계, 이미지 2/2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Screen Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Screen Replacement: 6 단계, 이미지 2/2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
    Use caution taking the board out as it does have some tabs that may hold it in place
    Andrew - 답글
  7. Samsung Galaxy Tab 4 7.0 Screen Replacement, Battery: 7 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Screen Replacement, Battery: 7 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Screen Replacement, Battery: 7 단계, 이미지 3/3
    • You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
    • Work the spudger underneath the battery as shown and pry the battery away from the phone case.
    • The battery is attached to the case with adhesive, so a bit of force is required during removal.
  8. Samsung Galaxy Tab 4 7.0 Screen Replacement, Screen: 8 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Screen Replacement, Screen: 8 단계, 이미지 2/2
    • Evenly heat the surface of the screen using your heating tool to loosen the adhesive that is holding the screen to the phone case.
    • If using the heating pad, you may have to reheat it once or twice during this process.
    • If you're using a heat gun, avoid heating one spot for more than a few seconds.
  9. Samsung Galaxy Tab 4 7.0 Screen Replacement: 9 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Screen Replacement: 9 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Screen Replacement: 9 단계, 이미지 3/3
    • Carefully insert the spudger between the glass and the chrome outer frame of the tablet.
    • Now, slowly pry your way around the screen to loosen the glass from the frame.
  10. Samsung Galaxy Tab 4 7.0 Screen Replacement: 10 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Screen Replacement: 10 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Screen Replacement: 10 단계, 이미지 3/3
    • After you’ve removed the glass from the screen, feed the chip connection through the phone casing.
    • The screen may need a little more force to separate from the upper edge of the tablet.
    This was rather easy. I have been trying to find a place where install/repair guides are accurate and reliable. Thanks iFixIt. Thanks to you, "I FiXED it"!
    fixitbrosmsus - 답글
    Can you also include how to replace the LCD screen under the digitizer? Thanks.
    B - 답글
    do I have to remove the mother board to replace the digitizer?
    crazychris79 - 답글
    I think the only concern by not removing the MoBo would be heating up the components with either a Heat gun or the Heat Pad.
    Lawrence -
결론
다른 36명이 해당 안내서를 완성하였습니다.
Aubrey Goodwin
회원 가입일: 08/31/15
2,700 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G3
4 회원들
안내서 12개 작성하였습니다
댓글 11개
Where is the microfuse located?
bbruns - 답글
Do you have to remove the battery to replace the screen?
Vic Rector - 답글
This is digitizer replacement guide - not screen replacement !!
K P - 답글
This worked perfectly for me. Thank you!
gjarmour - 답글
This worked perfectly for me. I just bought the assembly instead of going through the full deal (which if I had it would have saved me about 30 bucks overall). But was easy enough to do anyway. I still intend to get the digitizer/glass and finish so I have a spare for future breaks. (I have kids and they are hard on these tablets)
gjarmour - 답글
After successfully replacing the screen, and reassembling the unit according to the directions, I have a problem with the display image. The unit turns on, but the image does not come on unless I plug un the charger. The image displayed is of the charging batter segmented on 3 different parts of the screen, and lines similar to a schematic. I’ve disassemble the unit, checked the connections, all appear tight, reassembled and the issue is still present.
Any suggestions of what else to look for?
Jim Mason - 답글
That may be the Samsung battery (actually a single cell) not connected due to the ribbon contacts not mated correctly. Open the phone and check the ribbon connector. Be sure its tip fits flat inside the slot, and the tiny cover fitted on it.
rayramirez -
This is overly complicated, only steps 1,4,5 and 10-12 are relevant to replacing the digitizer glass.
Also, no mention of removing old adhesive with isopropyl alcohol to ensure a smooth fit for the new digitizer
brendon - 답글
As per the previous comment.
Brendon Gould - 답글
When reassembling the back cover, be extremely careful to fit the cover sideways over the three micro switches (on the right side when seen from the front). These are the power, volume up, and volume down switches. If you fit the back cover incorrectly, the switches may be blocked and not work, or worse be torn off the motherboard. I am writing this because this is what happened to me! I tore off the power switch and I had to salvage the switch from a different tablet to replace it. And that switch is extremely tiny!!
rayramirez - 답글
Screen keeps changing
Lorraine Rego - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 37
전체 시간: 46,173
