주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 4 7.0 Speaker Replacement
필요한 것
  1. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: 1 단계, 이미지 2/2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Speaker Replacement: 2 단계, 이미지 1/1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: 3 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: 3 단계, 이미지 2/2
    • In order the speaker connection, you must first peel back part of the surrounding water gasket.
    • With the tweezers, grab the overhanging corner and peel the gasket back slowly.
    • If you look closely, you will see the two slots indicated. Use the tweezers to lift this portion of the connection away from these slots.
  4. Samsung Galaxy Tab 4 7.0 Speaker Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Speaker Replacement: 4 단계, 이미지 2/2
    • Now you should be able to lift the speaker out of it's small fitting with the tweezers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Aubrey Goodwin
회원 가입일: 08/31/15
2,700 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G3
4 회원들
안내서 12개 작성하였습니다
댓글 2개
Where can I order the new speaker?
Dorrie Stotko - 답글
This would be better if it were a YouTube video so we could actually see it being done.
robinmyrobin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 3,915
