주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Motherboard: 1 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Motherboard: 1 단계, 이미지 2/2
    • Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
    • Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
  2. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 2 단계, 이미지 3/3
    • Carefully remove the back panel from the frame of the device.
  3. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 3 단계, 이미지 3/3
    • Using a Phillips #00 Screwdriver, remove the five 4 mm screws connecting the motherboard to the frame of the device.
  4. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 4 단계, 이미지 3/3
    • Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
    • Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
  5. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 5 단계, 이미지 3/3
    • Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
    • Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
  6. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 6 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 6 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 6 단계, 이미지 3/3
    • Disconnect the wire near the bottom of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  7. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 7 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 7 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 7 단계, 이미지 3/3
    • Disconnect the wire near the top of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  8. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 8 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 8 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 8 단계, 이미지 3/3
    • Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
    • Several plastic tabs keep the motherboard in place, so you will have to apply some force.
  9. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Front-Facing Camera: 9 단계, 이미지 1/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Front-Facing Camera: 9 단계, 이미지 2/3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Front-Facing Camera: 9 단계, 이미지 3/3
    • Flip the motherboard over to view the back side.
    • Locate the front-facing camera on the motherboard.
  10. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 10 단계, 이미지 2/2
    • Use a plastic opening tool to unlock the front-facing camera wire from the motherboard by flipping-up the retainer flap.
  11. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 11 단계, 이미지 1/2 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: 11 단계, 이미지 2/2
    • Use your fingers to grip the camera and carefully pull it out and away from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Valentina Franco
회원 가입일: 10/03/16
434 평판
안내서 4개 작성하였습니다
Cal Poly, Team 18-3, Forte Fall 2016 Cal Poly, Team 18-3, Forte Fall 2016 회원
CPSU-FORTE-F16S18G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 765
