주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 4 8.0 Verizon Display Replacement
필요한 것
  1. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement, Motherboard: 1 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement, Motherboard: 1 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement, Motherboard: 1 단계, 이미지 3/3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
  2. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 2 단계, 이미지 3/3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
  3. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 3 단계, 이미지 3/3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
  4. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 4 단계, 이미지 3/3
    • Using the spudger gently wedge the blue wire out of its compartment.
  5. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 5 단계, 이미지 1/1
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
  6. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 6 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 6 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
  7. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 7 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 7 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 7 단계, 이미지 3/3
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
  8. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 8 단계, 이미지 2/2
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
  9. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 9 단계, 이미지 1/1
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
  10. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 10 단계, 이미지 2/2
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
  11. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement, Display: 11 단계, 이미지 1/1
    • Insert an opening pick in between the display screen and the display frame.
  12. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 12 단계, 이미지 1/1
    • Wedge four of the opening picks in between the display screen and the device backing on all four corners.
  13. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 13 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 13 단계, 이미지 2/2
    • Wedge the Jimmy between the display and the device backing at a corner.
    • Cut through the adhesive that is securing the screen to the device on all four sides.
  14. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 14 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: 14 단계, 이미지 2/2
    • Once the display is completely disconnected from the device gently remove it without touching the screen which lies underneath.
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Umm….how do you remove the rear cover?
Gregg Stanley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 499
