주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Rear Case: 1 단계, 이미지 3/3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 2 단계, 이미지 2/2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 3 단계, 이미지 2/2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 3/3
    • The front camera's ribbon cable is located just above the battery, slightly to the left.
    • Carefully insert the flat end of the blue plastic opening tool under the connector at the end of the ribbon cable.
  5. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 5 단계, 이미지 1/1
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the front camera’s gold rectangular connector from its socket on the motherboard.
  6. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 6 단계, 이미지 2/2
    • Squeeze the gold rectangular piece with the tweezers to gently lift it from its pit.
결론
Ofelia Cruz
회원 가입일: 09/14/15
1,119 평판
안내서 5개 작성하였습니다
CSU Fullerton, Team 1-3, Bruce Fall 2015 CSU Fullerton, Team 1-3, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G3
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 497
