주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement
필요한 것
  1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Case: 1 단계, 이미지 3/3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 2 단계, 이미지 2/2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 3 단계, 이미지 2/2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Front Facing Camera: 4 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Front Facing Camera: 4 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Front Facing Camera: 4 단계, 이미지 3/3
    • The front camera's ribbon cable is located just above the battery, slightly to the left.
    • Carefully insert the flat end of the blue plastic opening tool under the connector at the end of the ribbon cable.
  5. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 5 단계, 이미지 1/1
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the front camera’s gold rectangular connector from its socket on the motherboard.
  6. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 6 단계, 이미지 2/2
    • Squeeze the gold rectangular piece with the tweezers to gently lift it from its pit.
  7. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Facing Camera: 7 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Facing Camera: 7 단계, 이미지 2/2
    • The back camera will be located near the top of the tablet in the center above the battery.
    • Carefully insert the flat end of the blue plastic opening tool under the metal rectangular end of the back camera’s cable connector.
  8. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 8 단계, 이미지 1/1
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the back camera’s metallic rectangular connector from its socket on the logic board.
  9. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 9 단계, 이미지 2/2
    • Squeeze the metallic rectangular piece with the tweezers to gently lift it from it's pit.
  10. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Battery: 10 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Battery: 10 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Battery: 10 단계, 이미지 3/3
    • Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).”
    • Remove the sticker to form a tab.
  11. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 11 단계, 이미지 1/1
    • Using your thumb and index finger, pinch the tab and pull it up to remove the top right corner of the battery from the front panel assembly.
    • If battery resistance is encountered due to adhesive, use the flat end of a spudger to run in between the battery and the front panel assembly.
    • Do not completely detach the battery just yet, doing so can cause damage to the red and blue cables loacted at the bottom of the battery.
  12. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 12 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 12 단계, 이미지 2/2
    • Starting at the bottom left side of the battery, gently remove the green tape.
    • Salvage the green tape if the replacement battery does not include one.
  13. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 13 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 13 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 13 단계, 이미지 3/3
    • Run the spudger under the battery to disconnect the red and blue cable connector from the circuit.
    • Lift the battery towards you, away from the front panel.
  14. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Motherboard: 14 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Motherboard: 14 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Motherboard: 14 단계, 이미지 3/3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
  15. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 15 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 15 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 15 단계, 이미지 3/3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
  16. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 16 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 16 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 16 단계, 이미지 3/3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
  17. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 17 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 17 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 17 단계, 이미지 3/3
    • Using the spudger gently wedge the blue wire out of its compartment.
  18. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 18 단계, 이미지 1/1
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
  19. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 19 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 19 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 19 단계, 이미지 3/3
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
  20. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 20 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 20 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 20 단계, 이미지 3/3
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
  21. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 21 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 21 단계, 이미지 2/2
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
  22. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 22 단계, 이미지 1/1
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
  23. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 23 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: 23 단계, 이미지 2/2
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ofelia Cruz
회원 가입일: 09/14/15
1,119 평판
안내서 5개 작성하였습니다
CSU Fullerton, Team 1-3, Bruce Fall 2015 CSU Fullerton, Team 1-3, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G3
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 2,711
