주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement
필요한 것
  1. Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement, Rear Case: 1 단계, 이미지 3/3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement: 2 단계, 이미지 2/2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement: 3 단계, 이미지 2/2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement, Power/Lock and Volume Button: 4 단계, 이미지 1/3 Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement, Power/Lock and Volume Button: 4 단계, 이미지 2/3 Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement, Power/Lock and Volume Button: 4 단계, 이미지 3/3
    • The button will be attached to the back casing of the tablet.
    • Using the spudger, first push the power/lock button then the volume button inwards from the opening towards the center of the tablet.
  5. Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement: 5 단계, 이미지 1/1
    • Using a precision tweezer, detach the clear plastic wire from the back casing by pulling the wire out of its slot.
  6. Samsung Galaxy Tab 4 8.0 Verizon Power/Lock and Volume Button Replacement: 6 단계, 이미지 1/1
    • Grab the power/volume button with a precision tweezer to completely lift the buttons out of the back casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ofelia Cruz
회원 가입일: 09/14/15
1,119 평판
안내서 5개 작성하였습니다
CSU Fullerton, Team 1-3, Bruce Fall 2015 CSU Fullerton, Team 1-3, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G3
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 1,728
