이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
Firmly grasp the back plastic casing and lift it away from the front assembly panel.
The button will be attached to the back casing of the tablet.
Using the spudger, first push the power/lock button then the volume button inwards from the opening towards the center of the tablet.
Using a precision tweezer, detach the clear plastic wire from the back casing by pulling the wire out of its slot.
Grab the power/volume button with a precision tweezer to completely lift the buttons out of the back casing.
다른 2명이 해당 안내서를 완성하였습니다.
