소개
After damaging your rear-facing camera, you might feel intimidated to dig into the Samsung Galaxy Tab 4 8.0. Replacement of the camera will only require a plastic opening tool, tweezers, muscle strength, and these easy to follow instructions.
도구
부품
At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
The back camera will be located near the top of the tablet in the center above the battery.
Carefully insert the flat end of the blue plastic opening tool under the metal rectangular end of the back camera’s cable connector.
다른 2명이 해당 안내서를 완성하였습니다.
