주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Case Replacement
필요한 것
  1. Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Case Replacement, Rear Case: 1 단계, 이미지 1/1
    • Before you being the replacement process, make sure the tablet is completely powered off.
    • Gently insert the plastic opening tool between the metal rim and the back plastic casing at the bottom of the tablet and pry the back casing away from the device. Continue to separate the back panel of the device from the front assembly.
    • Right-handed users will probably be more comfortable prying in a clockwise movement, while left-handed users will feel more comfortable doing a counter clockwise movement.
    • When taking off the rear case there will be periodic clicking noises. Do not worry about those noises. They are just the rear case being disconnected.
    • Be careful not to use too much force as the plastic clips can easily be broken.
  2. Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Case Replacement: 2 단계, 이미지 1/1
    • Place the tablet screen down on a clean surface.
    • Grasp the back panel and lift it from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Cameron Morrow
회원 가입일: 04/14/16
384 평판
안내서 3개 작성하였습니다
Cal Poly, Team 25-3, Maness Spring 2016 Cal Poly, Team 25-3, Maness Spring 2016 회원
CPSU-MANESS-S16S25G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 642
