주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 7.7 Battery Replacement
필요한 것
  1. Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: 1 단계, 이미지 1/3 Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: 1 단계, 이미지 2/3 Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: 1 단계, 이미지 3/3
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Battery Replacement, Disconnecting the battery: 2 단계, 이미지 1/1
    • Detach the five wire connection of the battery from the motherboard. You will need to gently insert a flat head screwdriver under the connector, and using left to right motion with your wrist, create a small space separating the connector from its connection. Gradually make the space wider until the connector pops out of its socket.
  3. Samsung Galaxy Tab 7.7 Battery Replacement, Unscrewing the battery: 3 단계, 이미지 1/1
    • Remove the 6 screws securing battery.
  4. Samsung Galaxy Tab 7.7 Battery Replacement, Replacing the battery: 4 단계, 이미지 1/1
    • Remove the original battery, replace it with a new one.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Stephanie Wong
회원 가입일: 09/26/14
973 평판
안내서 5개 작성하였습니다
USF Tampa, Team 13-2, Staggers Fall 2014 USF Tampa, Team 13-2, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G2
4 회원들
안내서 9개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 43
전체 시간: 7,521
