주요 콘텐츠로 건너뛰기
소개
Use this guide to replace the audio jack when it either ceases to function, or is functioning incorrectly.
  1. Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet. Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet. Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet.
    • Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet.
  2. Detach the connector that connects the audio jack to the flex cable.
    • Detach the connector that connects the audio jack to the flex cable.
  3. Use the Phillips #00 screwdriver to remove the 2 screws that secure the audio jack in place.
    • Use the Phillips #00 screwdriver to remove the 2 screws that secure the audio jack in place.
  4. Pick up and remove the defective audio jack. Pick up and remove the defective audio jack.
    • Pick up and remove the defective audio jack.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Stephanie Wong
회원 가입일: 2014년 09월 26일
973 평판
안내서 5개 작성하였습니다
USF Tampa, Team 13-2, Staggers Fall 2014 USF Tampa, Team 13-2, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G2
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 604
