주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 7.7 Motherboard Replacement
필요한 것
  1. Samsung Galaxy Tab 7.7 Motherboard Replacement, Opening the tablet: 1 단계, 이미지 1/3 Samsung Galaxy Tab 7.7 Motherboard Replacement, Opening the tablet: 1 단계, 이미지 2/3 Samsung Galaxy Tab 7.7 Motherboard Replacement, Opening the tablet: 1 단계, 이미지 3/3
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Motherboard Replacement, Disconnecting the circuit board: 2 단계, 이미지 1/1
    • Detach the ribbon cable.
  3. Samsung Galaxy Tab 7.7 Motherboard Replacement, Disconnecting  the thin connector cable: 3 단계, 이미지 1/2 Samsung Galaxy Tab 7.7 Motherboard Replacement, Disconnecting  the thin connector cable: 3 단계, 이미지 2/2
    • Disconnect the thin connector wire. Note the position both ends go to. There is a similar connection at one end of the wire that could be confused for the correct connection. Incorrectly reconnecting the wire upon re-assembly to this terminal will result in a malfunctioning unit!
  4. Samsung Galaxy Tab 7.7 Motherboard Replacement, Unscrewing the motherboard: 4 단계, 이미지 1/3 Samsung Galaxy Tab 7.7 Motherboard Replacement, Unscrewing the motherboard: 4 단계, 이미지 2/3 Samsung Galaxy Tab 7.7 Motherboard Replacement, Unscrewing the motherboard: 4 단계, 이미지 3/3
    • Remove the 4 screws securing the motherboard.
  5. Samsung Galaxy Tab 7.7 Motherboard Replacement, Replacing the motherboard: 5 단계, 이미지 1/2 Samsung Galaxy Tab 7.7 Motherboard Replacement, Replacing the motherboard: 5 단계, 이미지 2/2
    • Replace the original motherboard with the new circuit board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Stephanie Wong
회원 가입일: 09/26/14
973 평판
안내서 5개 작성하였습니다
USF Tampa, Team 13-2, Staggers Fall 2014 USF Tampa, Team 13-2, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G2
4 회원들
안내서 9개 작성하였습니다
댓글 한 개
Thanks for this post.
But, that was the speaker module and docking port assembly, not the motherboard!
The title is misleading!
valuesphilippines - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 3,185
