주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: 1 단계, 이미지 1/3 Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: 1 단계, 이미지 2/3 Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: 1 단계, 이미지 3/3
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Disconnecting the camera: 2 단계, 이미지 1/1
    • Detach the ribbon cable from the flex cable.
  3. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Removing the flex cable: 3 단계, 이미지 1/1
    • Detach all ribbon cables from the flex cable, unscrew the flex cable, and remove the flex cable. This needs to be done in order to remove the camera which sits underneath the flex cable.
  4. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Removing the camera: 4 단계, 이미지 1/1
    • Replace the original camera with the new camera. It should come right out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Stephanie Wong
회원 가입일: 09/26/14
973 평판
안내서 5개 작성하였습니다
USF Tampa, Team 13-2, Staggers Fall 2014 USF Tampa, Team 13-2, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G2
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 680
