주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 8.9 Battery Replacement
필요한 것
  1. Samsung Galaxy Tab 8.9 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  2. Samsung Galaxy Tab 8.9 Battery Replacement: 2 단계, 이미지 1/1
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  3. Samsung Galaxy Tab 8.9 Battery Replacement: 3 단계, 이미지 1/1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  4. Samsung Galaxy Tab 8.9 Battery Replacement: 4 단계, 이미지 1/1
    • Use your hands to open the back cover.
  5. Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: 5 단계, 이미지 1/3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: 5 단계, 이미지 2/3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: 5 단계, 이미지 3/3
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Battery Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Tab 8.9 Battery Replacement: 6 단계, 이미지 2/2
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Battery Replacement: 7 단계, 이미지 1/3 Samsung Galaxy Tab 8.9 Battery Replacement: 7 단계, 이미지 2/3 Samsung Galaxy Tab 8.9 Battery Replacement: 7 단계, 이미지 3/3
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: 8 단계, 이미지 1/3 Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: 8 단계, 이미지 2/3 Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: 8 단계, 이미지 3/3
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  9. Samsung Galaxy Tab 8.9 Battery Replacement: 9 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  10. Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: 10 단계, 이미지 1/3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: 10 단계, 이미지 2/3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: 10 단계, 이미지 3/3
    • Use a spudger to lift up and separate the battery from its housing.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Dan D
회원 가입일: 09/25/14
160 평판
안내서 1개 작성함
USF Tampa, Team 11-4, Blackwell Fall 2014 USF Tampa, Team 11-4, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S11G4
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Step 8 Clearer to say:
Insert the spudger under the red, black, and white cables to pry up the battery connector and detach it and the battery from the motherboard.
Paul Jackson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 21
전체 시간: 4,616
