소개
As a laptop battery ages, it will gradually lose the ability to hold a charge and die more quickly. This guide will show you how to replace your battery and bring life back to your laptop.
필요한 것
Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
Insert the spudger under the red, black, and white cables.
Pry up and detach the battery from the motherboard.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Step 8 Clearer to say:
Insert the spudger under the red, black, and white cables to pry up the battery connector and detach it and the battery from the motherboard.
