주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 8.9 Front Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Tab 8.9 Front Facing Camera Replacement, Insert Opening tool: 1 단계, 이미지 1/1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 Front Facing Camera Replacement, Insert second tool: 2 단계, 이미지 1/1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 Front Facing Camera Replacement: 3 단계, 이미지 1/1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 Front Facing Camera Replacement: 4 단계, 이미지 1/1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 Front Facing Camera Replacement, Locate Camera: 5 단계, 이미지 1/1
    • Camera can be found near the top center of device.
  6. Samsung Galaxy Tab 8.9 Front Facing Camera Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Tab 8.9 Front Facing Camera Replacement: 6 단계, 이미지 2/2
    • Using Spudger, lift connector from mother board
  7. Samsung Galaxy Tab 8.9 Front Facing Camera Replacement, Remove Camera: 7 단계, 이미지 1/3 Samsung Galaxy Tab 8.9 Front Facing Camera Replacement, Remove Camera: 7 단계, 이미지 2/3 Samsung Galaxy Tab 8.9 Front Facing Camera Replacement, Remove Camera: 7 단계, 이미지 3/3
    • Lift camera and remove from device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Aleezee True
회원 가입일: 09/30/14
532 평판
안내서 3개 작성하였습니다
USF Tampa, Team 11-4, Blackwell Fall 2014 USF Tampa, Team 11-4, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S11G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 373
