필요한 것
Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
Locate the motherboard and 5 connectors on it.
Pry up and detach the connector from the motherboard using the flat edge of the spudger.
Repeat for the 4 remaining connectors.
Using flat side of Spudger, lift orange tab connecting the flex ribbon of the camera to the motherboard.
거의 끝나갑니다!
결론
