주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 8.9 Vibration Motor Replacement
필요한 것
  1. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Insert Opening tool: 1 단계, 이미지 1/1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Insert second tool: 2 단계, 이미지 1/1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 3 단계, 이미지 1/1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 4 단계, 이미지 1/1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Battery: 5 단계, 이미지 1/1
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  6. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 6 단계, 이미지 1/1
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  7. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 7 단계, 이미지 1/1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  8. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 8 단계, 이미지 1/1
    • Use your hands to open the back cover.
  9. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Remove Green Tape: 9 단계, 이미지 1/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Remove Green Tape: 9 단계, 이미지 2/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Remove Green Tape: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  10. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 10 단계, 이미지 2/2
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  11. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 11 단계, 이미지 1/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 11 단계, 이미지 2/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 11 단계, 이미지 3/3
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  12. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Disconnect Battery from MotherBoard: 12 단계, 이미지 1/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Disconnect Battery from MotherBoard: 12 단계, 이미지 2/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Disconnect Battery from MotherBoard: 12 단계, 이미지 3/3
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  13. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 13 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  14. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Remove the Battery: 14 단계, 이미지 1/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Remove the Battery: 14 단계, 이미지 2/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Remove the Battery: 14 단계, 이미지 3/3
    • Use a spudger to lift up and separate the battery from its housing.
  15. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Motherboard: 15 단계, 이미지 1/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Motherboard: 15 단계, 이미지 2/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Motherboard: 15 단계, 이미지 3/3
    • Locate the motherboard and 5 connectors on it.
    • Pry up and detach the connector from the motherboard using the flat edge of the spudger.
    • Repeat for the 4 remaining connectors.
  16. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 16 단계, 이미지 1/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 16 단계, 이미지 2/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 16 단계, 이미지 3/3
    • Using the Phillips #00 screwdriver, unscrew the 3 screws (1mm) that are located near:
    • Camera
    • Power and volume buttons
    • Tilt sensor
  17. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 17 단계, 이미지 1/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 17 단계, 이미지 2/3 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 17 단계, 이미지 3/3
    • Using the flat edge of the spudger, pry and lift up the motherboard.
  18. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 18 단계, 이미지 1/2 Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 18 단계, 이미지 2/2
    • Pull away the motherboard from the housing.
  19. Samsung Galaxy Tab 8.9 Vibration Motor Replacement, Vibration Motor: 19 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to grab wire lead and gently lift to release glue holding wire lead to housing.
  20. Samsung Galaxy Tab 8.9 Vibration Motor Replacement: 20 단계, 이미지 1/1
    • Use opening tool to pry motor from housing.
결론
Eric Bird
회원 가입일: 05/09/17
543 평판
안내서 5개 작성하였습니다
IUPUI, Team S4-G2, Harley Spring 2017 IUPUI, Team S4-G2, Harley Spring 2017 회원
IUPUI-HARLEY-S17S4G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 218
