소개
This guide will walk you through the process of replacing a malfunctioning or broken vibration motor on a Samsung Galaxy Tab 8.9.
필요한 것
Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
Insert the spudger under the red, black, and white cables.
Pry up and detach the battery from the motherboard.
Locate the motherboard and 5 connectors on it.
Pry up and detach the connector from the motherboard using the flat edge of the spudger.
Repeat for the 4 remaining connectors.
Use tweezers to grab wire lead and gently lift to release glue holding wire lead to housing.
