주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A (2019) Screen Replacement
필요한 것
동영상 지침
결론
다른 17명이 해당 안내서를 완성하였습니다.
Nick Myers
회원 가입일: 04/15/18
3,730 평판
안내서 26개 작성하였습니다
댓글 9개
si on a pas conserver le pcb qu’il enlève de l’écran cassé on peux le racheter ou?
Yacine Chennoufi - 답글
How do you heat up the screen to loosen the glue? Heat gun? Blow dryer? How do you keep from damaging it from getting too hot? Thanks :)
Justin Shields - 답글
Use a heat gun it will help that’s what I would do
nicholaswiding -
I tried this with a hairdryer. While there are probably options that work better, it still helped a lot. I am too much of a coward to use a heat gun, as I don't want to fry it, so I used my wifes hair dryer to the point where the tablet was very hot to the touch around the edge of the screen.
Kristian Jarmund -
Best and safest way to heat up a device to remove screen is with a heating mat………. i set mine at 75deg
Alan Sears - 답글
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 78
30일 전: 304
전체 시간: 14,534
