필요한 것
동영상 지침
거의 끝나갑니다!
결론
다른 17명이 해당 안내서를 완성하였습니다.
댓글 9개
si on a pas conserver le pcb qu’il enlève de l’écran cassé on peux le racheter ou?
Yacine Chennoufi - 답글
How do you heat up the screen to loosen the glue? Heat gun? Blow dryer? How do you keep from damaging it from getting too hot? Thanks :)
Justin Shields - 답글
Use a heat gun it will help that’s what I would do
nicholaswiding -
I tried this with a hairdryer. While there are probably options that work better, it still helped a lot. I am too much of a coward to use a heat gun, as I don't want to fry it, so I used my wifes hair dryer to the point where the tablet was very hot to the touch around the edge of the screen.
Kristian Jarmund -
Best and safest way to heat up a device to remove screen is with a heating mat………. i set mine at 75deg
Alan Sears - 답글
