주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A 10.1 Back Panel Replacement
필요한 것
  1. Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: 1 단계, 이미지 2/2
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Back Panel Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab A 10.1 Back Panel Replacement: 2 단계, 이미지 2/2
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Isabella Li
회원 가입일: 10/02/17
2,376 평판
안내서 7개 작성하였습니다
Cal Poly, Team S15-G6, Livingston Fall 2017 Cal Poly, Team S15-G6, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G6
4 회원들
안내서 26개 작성하였습니다
댓글 한 개
Why need to remove cables when only the back has to be replaced ?
nabe_03 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 18
30일 전: 91
전체 시간: 11,945
