주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A 10.1 Back Panel Replacement
필요한 것
  1. Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: 1 단계, 이미지 2/2
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
    AWESOME!! I was trying to open it from the “NOT OK” place and you saved me to broken the screen… thanks!!
    David Leiva - 답글
    No problem, enjoy.
    Roger L. Ortiz -
    Felt it was easier for me to do it from the middles out.
    Tanin Garcia - 답글
    @rogerlortiz You two seem to be miscommunicating. The author points out the location between the digitizer and frame in which to place a tool. While @Tanin Garcia, whom no longer seems to be member, was pointing out where along the edge from corner to corner it was best to start the separating process.
    B. A. Computer Services -
    Important: the display is sourrounded with a plastic frame. You need to get beween this frame an the backcover (not directly at glass edge as I tried it first and almost broke the glass). Get a closeup picture of it to clarify.
    Oliver Dawid - 답글
    wer lesen kann, ist klar im Vorteil - ich hab die SD-Karte drin gelassen. Hat aber funktioniert…
    Thomas Wolter - 답글
    Don’t use a very small flathead screwdriver as a spudger. Just shattered the screen :(
    nikvoss - 답글
    Yes, shattered the screen. To the garbage, it goes. A little knowledge is a dangerous thing. This a repair better suited for a professional repair! Thanks for helping me make the decision to get another one!
    vancega - 답글
  2. Samsung Galaxy Tab A 10.1 Back Panel Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab A 10.1 Back Panel Replacement: 2 단계, 이미지 2/2
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Isabella Li
회원 가입일: 10/02/17
2,364 평판
안내서 7개 작성하였습니다
Cal Poly, Team S15-G6, Livingston Fall 2017 Cal Poly, Team S15-G6, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G6
4 회원들
안내서 26개 작성하였습니다
댓글 한 개
Why need to remove cables when only the back has to be replaced ?
nabe_03 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 19
30일 전: 82
전체 시간: 11,756
