주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A 10.1 Battery Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy Tab A 10.1 Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab A 10.1 Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Battery Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab A 10.1 Battery Replacement: 2 단계, 이미지 2/2
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
  3. Samsung Galaxy Tab A 10.1 Battery Replacement, Disconnecting the battery: 3 단계, 이미지 1/1
    • Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
    • Slide the orange battery ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab A 10.1 Battery Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab A 10.1 Battery Replacement: 4 단계, 이미지 2/2
    • Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
  5. Samsung Galaxy Tab A 10.1 Battery Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab A 10.1 Battery Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab A 10.1 Battery Replacement: 5 단계, 이미지 3/3
    • Lift the retaining tab and withdraw the black LCD ribbon.
  6. Samsung Galaxy Tab A 10.1 Battery Replacement, Battery removal: 6 단계, 이미지 1/2 Samsung Galaxy Tab A 10.1 Battery Replacement, Battery removal: 6 단계, 이미지 2/2
    • Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
    • Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
    • The large rectangular white and black piece is the entire battery. Be careful not to puncture it.
결론
다른 46명이 해당 안내서를 완성하였습니다.
Isabella Li
회원 가입일: 10/02/17
2,376 평판
안내서 7개 작성하였습니다
Cal Poly, Team S15-G6, Livingston Fall 2017 Cal Poly, Team S15-G6, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G6
4 회원들
안내서 26개 작성하였습니다
댓글 9개
Used this guide up until the disconnecting of the battery in order to fix the black screen of death. Very very helpful. Thank you.
Steffan Syd Apel - 답글
If you have my kind of bad luck — where the latch for the battery flex cable connector sticks to the tape when you remove the tape, and then it will not snap back into place — don’t worry about it too much, because the connector tension will hold the flex cable in place. Just put the tape back over the top as directed.
Richard Ekblaw - 답글
Why does it say you need a heat gun?
Geert Pante - 답글
To loosen the adhesive. A hair dryer works well too
qaisraja22 -
how to calibrate the new battery?
when device switched off due to 0% of battery - there is impossible to boot it even with charging. there is required to open a tablet and charge the battery from another source.
Алексей Хейдоров - 답글
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 97
30일 전: 426
전체 시간: 64,808
