주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Have the front of the device facing you. Begin near one of the curved edges of the device (see photo two for visual example).
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels. Lift the back panel off of the device.
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
    • Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
    • Slide the orange battery ribbon cable out of the ZIF connector.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon. Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
    • Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Lift the retaining tab and withdraw the black LCD ribbon. Lift the retaining tab and withdraw the black LCD ribbon. Lift the retaining tab and withdraw the black LCD ribbon.
    • Lift the retaining tab and withdraw the black LCD ribbon.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery. Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
    • Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
    • Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
    • The large rectangular white and black piece is the entire battery. Be careful not to puncture it.
  7. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Flip up the two ZIF connectors on the motherboard using the plastic opening tool. Slide the orange ribbon cables out of the ZIF connectors. Remove the front-facing camera.
    • Flip up the two ZIF connectors on the motherboard using the plastic opening tool.
    • Slide the orange ribbon cables out of the ZIF connectors.
    • Remove the front-facing camera.
  8. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Disconnect the headphone jack from the motherboard.
    • Disconnect the headphone jack from the motherboard.
    • Use a Phillips # 000 to remove six 4mm screws.
  9. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Lodge the plastic opening tool under and lift the motherboard out of the tablet. Be careful not to snag any connectors.
    • Lodge the plastic opening tool under and lift the motherboard out of the tablet.
    • Be careful not to snag any connectors.
    • Remove the metal bracket that was underneath the charging port and set aside.
  10. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    The screen may crack during removal, so be wary of broken glass. Apply heat as necessary around the edges of the screen to loosen the adhesive, but be careful not to melt the plastic frame of the tablet. Starting on the side of the tablet near the bottom, heat the area and insert a metal jimmy or opening pick between the digitizer and the frame.
    • The screen may crack during removal, so be wary of broken glass. Apply heat as necessary around the edges of the screen to loosen the adhesive, but be careful not to melt the plastic frame of the tablet.
    • Starting on the side of the tablet near the bottom, heat the area and insert a metal jimmy or opening pick between the digitizer and the frame.
    • Separate the adhesive on the bottom of the tablet first, then work up the sides. The digitizer ribbon cable is located at the top and passes through a slot in the mid-frame. It is easily torn or damaged in the final stages of removing the glass.
    • If the glass is intact and you intent ro reuse it, take care not to insert the jimmy further than the width of the black screen border or you risk damaging the digitiser, which is a thin plastic film stuck to the bck of the glass.
    • The adhesive tends to stick to the plastic mid-frame rather than the glass but it will separate more easily and cleanly from the midframe if you can start it lifting at one point. This will also reduce the risk of damaging the digitiser film.
  11. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Turn the tablet over and lodge the plastic opening tool under the screen to take it out of the device.
    • Turn the tablet over and lodge the plastic opening tool under the screen to take it out of the device.
    • The LCD panel is stuck to the mid-frame with double sided tape. Lift gently and progressively, giving the adhesive time to give way.
결승점
다른 35명이 해당 안내서를 완성하였습니다.
Isabella Li
회원 가입일: 2017년 10월 02일
1,916 평판
안내서 7개 작성하였습니다
Cal Poly, Team S15-G6, Livingston Fall 2017 Cal Poly, Team S15-G6, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G6
4 회원들
안내서 21개 작성하였습니다
Will be trying this in the next couple of days, see there was no heat gun used to take the front glass off, I’m only replacing the LCD so does the touch glass need warming to remove or does it just jimmy off?
tcatt - 답글
I would Personally HIGHLY RECOMMEND Heat.
this Guide Perturbs me slightly.It never detaches the battery from motherboard and misses a couple of the Connectors it feels like its skipping steps.
iCovers Customer Service -
After replacing the digitizer, my soft keys do not function. The home button works just fine, but i cannot press the back button or the recent application button. Would this be due to a faulty digitizer? Or could it possibly be a faulty ‘ daughter board “? ( not positive if the home button working excludes this theory )
Lance Basinger - 답글
Same problem here. Did u fix a fix?
Jesse Martucci -
Same here HAS ANYONE SOLVED THIS ISSUE
Collin Babb -
댓글 쓰기
조회 통계:
24 시간 전: 87
7일 전: 620
30일 전: 2,673
전체 시간: 72,198
