주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement, Front Facing Camera: 1 단계, 이미지 1/1
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement: 2 단계, 이미지 2/2
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers, at the end of the gold wire, gently lift the black tab locking the wire connecting the camera to the motherboard.
    • Pull the wire from the connector, disconnecting the camera from the device entirely.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Bradley Watson
회원 가입일: 02/15/17
1,079 평판
안내서 4개 작성하였습니다
USF Tampa, Team 5-4, Passmore Spring 2017 USF Tampa, Team 5-4, Passmore Spring 2017 회원
USFT-PASSMORE-S17S5G4
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 27
전체 시간: 2,448
